They are the positive stop. So fitment is important. I made the bump fit the divot, as it is easier to remove a small amount at a time then weld in more. Yes you need one turn to clear and a couple thousandths additional as the block has not made a full revolution until it passes the bump, so the bump is less than the .050”. It has no bearing on recoil fortunately.
Pierre
