- Feb 2, 2013
- 3,538
the jumpers i was referring to are small metal clips that connect the poles of the switch
if you loosen the wire holding screws enough , you may be able to remove the jumpers and configure the switch at will.
but a wiring diagram will take a lot of guesswork and thinking out of the equation.
if i were right next to you, i'd be able to tell you in 2 seconds, but i'm at a slight disadvantage here 1800 miles away and all
i'm happy to help when you need it.
