[4]
Wood Dust and My HF 44991 Mini Mill
[3]
[10] Like what you see?
ctgull
Newbie
Sep 6, 2018
8
I have a HF 44991 coming in 5 days and I plan on mounting it to my workbench in the garage. I'm not thrilled with it being exposed to the temperature and humidity extremes. There's an outside chance I might be able to fit in my inside work space if I eliminate some stuff. Of course I'll build a rolling stand with lexan guards to contain some of the chips. There's usually wood chips on the floor anyway. If you haven't read my Intro, I fix acoustic guitars for fun. The mill will be to make wooden parts and metal/plastic tools/fixtures. I'm a Tool Designer by trade.
Along with the environmental extremes, I'm concerned about the amount of wood dust I make. I use my band & miter saws, and various sanders a lot. Not daily, but the amount of wood dust adds up. I don't want that fouling up the ways and other moving parts of my new mini mill.
My thoughts are to throw a sheet/blanket/tarp over it when I'm not using it. Another idea is to build a lexan enclosure that I can close and semi seal. Obviously the enclosure takes up space and will get in the way of operation. It will also eliminate air movement and possible promote rust.
Any suggestions?
stupoty
Dec 2, 2012
1,147
Any suggestions?
Summery of overly verbose answer "cotton drop sheets from builders merchents" ;)
I have a small subteranian outdoor workshop with a cement rendered celing/wall (it's arched), I got into dust covers when I realised how much concreat dust fell on the lathe ways I use the cotton drop sheets from a builders merchent. They are not to expensive and are quite durable.
They arn't moisture proof, which I believe helps with not having condensation issues. If it's been very wet or I think they might have a hint of dampness I hang them up to dry.
Stu
francist
Sep 5, 2013
1,190
I'd forget about any rigid enclosure and use the drop sheet idea too. I have a small blanket over my lathe that's easy enough to throw on and off whenever I use it.
From another post I see that milling machine is pretty compact. This might sound goofy, but you may even be able to find a large pillow case at the thrift store that would slip over top. Having the fabric sewn into the bag shape to begin with makes for less ball-up of excess around the base. Much neater appearance.
-frank
homebrewed
Active Member
Jul 28, 2017
212
For years I had my 7x12 in an unheated garage. Our damp Oregon winters meant there was a high risk of rust. When not using it, I put a heating pad underneath it and put an old blanket over it. Kept it nice & warm, no rust. And a lot more pleasant to use that time of year!
I guess that's one advantage of a benchtop-sized lathe. They're small enough to do something like that.
Now the 7x12 lives in a new, dry basement so I don't need the heating pad (at least not for the lathe) any more.
hman
H-M Platinum Supporter ($50)
Feb 17, 2013
2,046
I lived in Oregon for quite a few years, with my shop space inside a detetched, unheated garage. I'll gladly endorse everything homebrewed said. Spring and fall were the worst - everything near freezing cold for weeks on end, and then a wet warm front would roll in. Every metallic surface would condense enough water to drip and run off! Had too many machines and things to go with heating pads, though I really should have. One thing that did work for me was to use either Boeshield T9 or Fluid Film on the machines. I'd spray it onto a rag and wipe on a light coating, thus avoiding a large build-up.
I also did (and still do!) a bunch of woodwork in my shop, including occasional wood cutting on my HF44991 mini-mill. After each job, I'd use chip brushes and a mini vacuum cleaner to get rid of the sawdust (woodswarf?), then re-apply some protectant if it seemed necessary. I also kept covers on the tools. Didn't think of using a pillowcase (as per francist), but that's a great idea for a mill! I plan to make use of it in my current shop. We have a couple major dust storms (haboobs) every year, and even with all the doors closed, enough dust gets inside the shop to be visible on surfaces.
John281
Nov 11, 2017
26
My wife made some custom covers for the mill and lathe using cloth-backed vinyl material. I know they're working because there is a fair amount of dust on them. I told her she could probably make some money selling custom fit covers to others. :)
NortonDommi
Active Member
Nov 15, 2016
449
I use old fitted bedsheets for lathe and mill covers. The elastic makes them easy to fit and they stay in place. Spring is officially here and I have a new shed to build but come next winter I intend to have one of the newer infrared heaters in place. Picking up an industrial dust extractor tomorrow as a good vacuum system goes a long way towards good health for man and machine. Just rigging up a vacuum cleaner through a cyclone or Thein collector is a big help. Have a look at some of the Silicon lubricants for ways and bright pieces as oil and wood dust are better than Neodymium magnets for attraction.
homebrewed
Active Member
Jul 28, 2017
212
Sounds like quite a change from the Oregon clime! Going from rust to dust, eh? :D
I had heard about Boeshield but wasn't sure how well it would work when things get _really_ damp. Good to know -- thanks!
dtsh
Sep 22, 2017
135
I'm another who uses dropcloths and sheets on my equipment. They're cheap and do a good job of keeping crap out while still being "breathable" enough to not build up moisture underneath.
ctgull
Newbie
Sep 6, 2018
8
An old sheet sounds good enough, while it's in the garage.
I'm trying to figure out a way to fit it (on a rolling stand, lexan on 4 sides to contain some of the chips) into my inside work space. It's very tight but there are a few things that aren't used and could be eliminated (if I don't tell the wife!). I'd build an open stand so I could roll my chair under it, instead of standing. I'd have the option of rolling it into the garage if I'm really going to make a mess, although the 5 inch drop could be a problem.
C-Bag
Ned Ludd's bro
Feb 9, 2017
677
We live on the coast and the motorcycle enthusiast across the street was the one who turned me on to old sheets. We had some sunbrella cloth left over from a project and my wife made a cover for my 9x20 lathe and a one for my 14" Starrett height gage. Both are rust free after 4yrs in the unheated garage. The sunbrella cloth is nice and stiff almost like a tarp and is water resistant but not water proof. So it breathes and doesn't condensate which I found out the hard way is no good. I also use a shop vac with a homemade cyclone and that's amazing for keeping dust down and for cleaning machinery without clogging the HEPA filter.
homebrewed
Active Member
Jul 28, 2017
212
Got any details on the cyclone filter?
Thanks.
C-Bag
Ned Ludd's bro
Feb 9, 2017
677
It was an experiment which worked a lot better than expected. I did a half way description on another home made tools site. It's all out of 8" ducting, 2" PVC and a 5gal bucket. I do a lot of powdercoat and not only does it go everywhere, it clogs a HEPA filter in a heartbeat. So the cyclone was way to get the powdercoat before it got to the shopvac. Can't believe how good it works for not knowing what I was doing :)
tcarrington
Making miscellaneous parts for years now
Dec 27, 2013
71
Same here as NortonDommi - fitted sheets to keep most of the particles off. Going to wipe it down every so often anyway.
Keep your workspace at least 5 degrees warmer than outside OR keep the humidity inside low enough that the machine is above dew point. Condensation occurs when the machine is below dew point. Rainy days are the hardest.
yendor
Dec 11, 2013
216
There are some pretty nice extra large GRILL Covers that will cover a pretty good sized lathe.
Look in Patio Furniture Covers and there is some stuff that could be re-purposed.
Jidis
Active Member
Jul 29, 2017
38
Banggood and probably other import dealers do a smaller heavy duty plastic one that looks similar to C-Bag's if you don't feel like building one. I've got one around here that I haven't gotten to try yet. IIRC, it was in the 20-30 USD range.
C-Bag
Ned Ludd's bro
Feb 9, 2017
677
It all depends on what you're trying to filter. Wood shavings and dust are not too difficult so I can see the small plastic cyclones and Thein type working fine. But powdercoat and dust from the blast cabinet are around 5microns and float forever. I reasoned from the big cyclones I used to see in the various plants I worked around that bigger is better. It's why I didn't go with the little plastic ones.
Jidis
Active Member
Jul 29, 2017
38
I didn't even realize those things did anything for small stuff. I've got a cyclone lid and galvanized trash can that I can't accommodate for my big dust collector, and thought it just knocked out the larger chunks. Been meaning to look into a finer filter bag for that one. I was hoping to use the smaller one on the Shopvac with some water in the canister to kill any hot stuff that made it through the hose.
jrkorman
Jan 22, 2017
74
Two things -
First - Drop cloths are a great idea, I'm in West Texas and anything out in the shop not covered, gets a coat of red dust!
Second - I picked up my HF mill from a guy that had been using it to do wood working (vaping stuff) and I was expecting to find
a lot more wood dust than I actually found when I got it home and cleaned it. And most of that was because the guy hadn't got all
of the factory goop off before he started using it.
I like the little shopvac idea mentioned.
ctgull
Newbie
Sep 6, 2018
8
After a 2 week pre-surgery diet, and 2 weeks recovering from surgery, I finally made some chips with my 44991!
After 5 days of rest I went out to the garage and spent 2 days building a stand for it. And I've been slowly ordering stuff from the Little Machine Shop. Got the 3" swivel vise & parallel set that was on sale 2 or 3 weeks ago. Have a collet set and endstop on order, that should be in tomorrow. Waiting for the belt drive conversion kit to go on sale. Eventually a 3 axis DRO. Need to get an edge finder. I tried to use a 1/4" dowel to find the edge and make two revs to get to the edge. Nope.
For now I'm going to have to detail everything dimensioned from the upper left corner, ot use the lower right corner and turn the drawing upside down. After watching people use Bridgeports for years, It's my turn to figure out how to use my 44991.
The 2 last guys in the Toolroom are retiring in the Spring. I should be able to inherit lots of good tooling
[6]
[5] [7]
