Worm gear for a homemade rotary table
Meleon69
H-M Supporter - Silver Member
Jan 28, 2018
15
D63995CC-FD53-495B-8DF3-9F2270F3F950.jpeg 87B28313-0EBA-48D7-814C-AB3535A7574D.jpeg
I robbed this worm gear set from a the gear box of an old walk behind snow blower. I’m hoping to use it for a rotary table build. I couple of questions.
1. How do I determine the gear ratio?
2. Will it be too be to be practical?
I can provide more measurements. Just tell me what measurements are needed
RJSakowski
H-M Supporter - Gold Member
Feb 1, 2015
5,292
One revolution of the worm advances the gear one tooth. 21 teeth so 21:1. That would be an odd number for an RT. Also an RT usually has a mechanism for taking up any slack to reduce backlash. This would be hard to accomplish with your gear set. However, if you are willing to do the math and only turn the table in one direction for its final setting, it could work.
RJSakowski
Feb 1, 2015
5,292
Each revolution of the worm would rotate the table 17.1429º or 17º 8' 34.29".
Meleon69
Jan 28, 2018
15
Thanks for the reply. I knew there must have a reason I couldn’t anybody using them for any but there intended purpose. They are pretty robust and seem well made.
MontanaLon
Mar 15, 2019
671
Following. A rotary table would be nice, being made of junk is not a negative in my book.
Meleon69
Jan 28, 2018
15
MontanaLon. This won’t break any speed records. My mill is currently in another province. Hope to fix that on the week. Stack that with the fact that I work a fly in fly out job. I’m home 1 week out of 3. But I’ll happily keep the group up to date with progress.
MontanaLon
Mar 15, 2019
671
I am in for the long haul. Still have to find a snow blower I can scavenge from.
Meleon69
Jan 28, 2018
15
The older ones from the 80’s have lots of shafts, bearings, and hex stock in them.
GrayTech
Jan 18, 2018
168
If the gearbox had other gears that mesh with that one you may be able to get a better ratio out of it.
RJSakowski
Feb 1, 2015
5,292
If you drove with a stepper motor rather than a hand crank, you could program in a nice round number for your gear ratio. At eight microsteps/step it would take 93 microsteps to move the table 1º. Actually 93-1/3 so you would never be in error by more than 12 seconds of arc.
An Arduino, a stepper, driver, and a power supply and your set. If you picked your parts carefully, it could be done for less than $50.
pontiac428
John Newman
Apr 23, 2018
1,493
One could cut a spur gear with 40 teeth for that 40:1 ratio, but I doubt it makes any difference in the universal world of mathematics. Multiples with more prime factors will give more flexibility. 21:1 is 7*3*3, which does not have a 2*2=4 factor. That will limit you for sure, but 12:1 or 20:1 or 24:1 sure has a lot of workable indexing options. Any ratio that goes into 360 evenly (1, 5, 30, 40, 180, whatever) is a good candidate for a simple degree wheel RT, without need for indexing plates.
I think the backlash compensation scheme on my Kamakura RT would work well against that worm gear. The gear would be bored and shafted on one side to work your handwheel. Against the opposite side, a simple plunger and spring would force the worm gear toward the handwheel side to squeeze the backlash out of the gear pair. You'd have to look at some pics of various RTs to make sense of what I said, but I think those parts are suitable for it if the OP were to pursue the idea further.
benmychree
John York
Jun 7, 2013
5,028
Why not just buy a 40:1 ratio set of worm and gear from your local bearing house or online stock gear source?
Meleon69
Jan 28, 2018
15
The worm gear was just something I remembered I had after robbing parts off the old blower. I do actually have a box of stepper motors and a couple of arduino kicking around
hman
H-M Platinum Supporter
Feb 17, 2013
2,821
I'm pretty sure it's 22 teeth, not 21 (counted twice, just to be sure). Nevertheless, it would still be an unusual number for an RT.
Meleon69
Jan 28, 2018
15
I've just pulled the trigger on a 3 axis DRO for my mill. Aliexpress 11-11 sale.
Should I decide to proceed with the rotary table it should help out a little. But on the flip side it might make necessity a little less.
Before I had the lathe I thought I knew of a million things I would make if only I had a lathe. Got the Lathe and thought seems everything I want to make on the lathe would be better if only I had a mill... now I'm stumped. Seems the only things I can think of to make is more tooling for the lathe and mill. lol I'm soon gonna have to show the wife these things are useful
MontanaLon
Mar 15, 2019
671
I also invested in the same dro. I've got a wife who doesn't pay attention to the details. That is really helpful when a new gun follows me home. If she notices at all she assumes I've always had it. And if she asks I tell her "that's my rifle/shotgun/pistol" and she never asks how long I've had it.
I am skating on thin ice there though as she has started to question why all of my guns used to fit in 1 safe and now occupy 2.
brino
Confirmed Tool User
H-M Lifetime Diamond Member
Jan 2, 2014
4,899
A little off-topic, my apologies to the OP....
hmmmmm............let's see if we can come up with some creative answers.....
1) the safe is shrinking with age/humidity.
2) the pistols do not get along with the rifles and I had to separate them.
3) the anit-rust coating on the rifles is turning the pistol grips funny colours.
4) don't want all my eggs in one basket.
Now back to the regularly scheduled thread......
-brino
AdBlock Detected
I've Disabled AdBlock
