Looking for a hand wheel with 1/2 bore and keyway maybe 6" or less dia. Want it for my 11" lathe
K Kroll Active User H-M Supporter Gold Member Joined Dec 23, 2012 Messages 1,307 Apr 14, 2018 #1 Looking for a hand wheel with 1/2 bore and keyway maybe 6" or less dia. Want it for my 11" lathe
D DAT510 H-M Supporter - Gold Member H-M Supporter Gold Member Joined Oct 20, 2016 Messages 720 Apr 14, 2018 #2 McMaster Carr is one option.
Glenn Brooks H-M Supporter - Gold Member H-M Supporter Gold Member Joined Nov 14, 2014 Messages 851 Apr 15, 2018 #3 Hand wheels,often come up on eBay. Might be worth logging a search for a few weeks to see what shows up.
K Kroll Active User H-M Supporter Gold Member Joined Dec 23, 2012 Messages 1,307 Apr 15, 2018 #4 Thanks guys,going shopping over on auction site,my wheel is 5" dia so maybe I can find one in that size
solo H-M Supporter - Sustaining Member H-M Platinum Supporter Joined Mar 23, 2013 Messages 149 Apr 21, 2018 #5 I have a few that came off a Index mill. I'll check the bore size.
solo H-M Supporter - Sustaining Member H-M Platinum Supporter Joined Mar 23, 2013 Messages 149 Apr 21, 2018 #6 I have two Alum 6" w/ 5/8-18 thread and one cast 7" same 5/8-18 I'll give you one if it will work out for you.
R Rob Registered Registered Joined Nov 19, 2011 Messages 328 Apr 21, 2018 #7 Grizzly Tools also sells cast hand wheels reasonably. You have to drill the bore and cut a keyway if needed.
