WTB -lantern, tool holders, drill chuck, dead chuck
Jim Huel
Mar 1, 2018
22
Got a lathe but little tooling. Need a tool holder, drill chuck, dead center, and, lowere priority, a 4 jaw chuck. Lathe is 14 in swing, 3 MT TS, D1-6. I'm thinking a lantern to start, but could go Aloris style if that works out.
Thanks for looking
I made myself an aloris type holder by bolting together 3 steel plates from underneath with 4 countersunk flat head screws. It only holds tools along 2 edges, but works well enough and cost me almost nothing. I have 2 washers of different thicknesses to adjust height of the entire holder, 1 for hss tools and 1 for brazed carbide as they have a different center height. It's not a quick change, but it works very well for my needs.
If your budget allows, I'd think you'd find, a QCTP such as an Aloris, Phase II+, or Generic, to be much more pleasant than a Lantern style tool post. QCTP's allow you to set the tool height once (unless you end up regrinding your tool). And as the name implies, they also allow you to quickly change your tooling. For me, when turning something, it allows me to concentrate on what I'm machining verse changing and realigning tooling, as I'd did when I used a Lantern style tool post.
I purchased an AXA Phase II Wedge Style with 5 holders off ebay for ~$200. Given the size of your lathe, you would probably need a BXA QCTP. Looks like the Phase II run about ~$250 for the BXA's. There are Shar's, CDCO's and other "brandless" QCTP Sets for less. There are lots of posting on H-M, with all the pro's and con's of all the brands, if you want to do any research.
