[4]
WTK RPM For 2 1/2 face mill
[3]
[10] Like what you see?
chiroone
Active Member
Apr 10, 2014
124
Likes
89
#1
I purchased a 2 1/2 inch face mILL from grizzly. It is the one that has the four replaceable carbide cutters. I’m wondering what is a good RPM for steel and aluminum. I have the PM 835 mill so I’m sure it’s rigid enough
T Bredehoft
Dec 27, 2014
2,792
Likes
2,135
#2
I don't have the speeds for your carbides on hand, but in aluminum you probably can't go fast enough.
benmychree
John York
Jun 7, 2013
2,751
Likes
1,992
#3
For steel, start out at about 250 SFM, or approximately 250 RPM; likely that could be increased, depending on what sort of steel it is and how easily it cuts, and of course, how the inserts hold up.
chiroone
Active Member
Apr 10, 2014
124
Likes
89
#4
Thanks, 250 RPM is a little slower than I would have expected.
benmychree
John York
Jun 7, 2013
2,751
Likes
1,992
#5
That is a starting point; try it and see how it performs likely you can run it faster; it is better so start low and increase than start high and wipe out the inserts. Perhaps my off the cuff recommendation was low, I've consulted my B&S cutting speed calculator for 100 BHN steel (soft), and they , which would be say to start at 450 FPM which would be 630 RPM; my mistake! For HSS, the FPM would be 150, the RPM would be 230.
chiroone
Active Member
Apr 10, 2014
124
Likes
89
#6
Thanks, I’m trying to cut 3/16 A36 hot rolled. So maybe I’ll try 250 RPM and see how that goes
benmychree
John York
Jun 7, 2013
2,751
Likes
1,992
#7
A36 should cut easily at higher speed.
P. Waller
H-M Platinum Supporter ($50)
Mar 10, 2018
813
Likes
533
#8
BFHammer
Jan 27, 2017
154
Likes
208
#9
I was using my 2 1/2" facemill last night on A36 with my PM932. My face mill is a 45degree model with 5 inserts and I found the sweet spot to be around 670RPM with the set up I was using. I found that I could run at 8IPM or more and get good results. Depth of cut also plays into the equation - I found (strictly by trial an error) that a .015 to .025 depth gave me good results.
When I have used my facemill on aluminum I go as fast as my machine will go 1970RPM.
P. Waller
Mar 10, 2018
813
Likes
533
#10
Kenna recommends up to 9000 SFM for some uncoated inserts in aluminum alloys with low Si with coolant.13000 RPM's at 2 1/2 inch diameter.
That is banging it hard, start low and over ride the spindle speed and feed as you go.
MarkM
Apr 23, 2017
314
Likes
228
#11
Nice to see you up and running. I am sure there are alot of people interested in the 835s. So any hint of a review? In the market and this is one on the list.
ddickey
Apr 21, 2016
1,884
Likes
934
#12
So was it able to hand the 2.5" face mill?
JCByrd24
Newbie
Mar 5, 2018
10
Likes
10
#13
My PM-30 handles a 2.5” facemill at 0.050” no problem, mine’s also a 45 degree type. I run 1500 rpm or a little less in steel and 3000 in aluminum. The SEHT inserts I have are unknown chinesium but similar at Shars show 600-1200 sfpm or something crazy.
chiroone
Active Member
Apr 10, 2014
124
Likes
89
#14
I was planning on doing a review on the 835. I have a DRO on order from precision Matthews. Unfortunately, my garage is filled with a lot of stuff I had in storage from my recent move. Might be a few weeks before I have everything cleared out and not yet had the opportunity to run the face mill as yet
MarkM
Apr 23, 2017
314
Likes
228
#15
Any thoughts on the mill? Ready to purchase a mill. One on my radar. Looks great! How are the castings if you haven t run it. Not worried about the head.
chiroone
Active Member
Apr 10, 2014
124
Likes
89
#16
The castings in the base are slightly above average for a Chinese machine. It has its share of Bondo to hide some of the casting imperfections. However, I would say the table ways and dovetails are tight and well machined. I will also say that the one pump oiling system is a humongous plus. I was able to maintain about .001 On the entire x axis travel. I was speaking to Matt a few days ago about the installation of a DRO I purchased from him and he commented to me he only has one more 835 left. Another shipment is not expected till September. So if you were on the fence, I would act quickly .
MarkM
Apr 23, 2017
314
Likes
228
#17
Chiroone you say you held .001 across the entire x axis. Is this the best you could achieve after tramming the head? Ready to purchase a mill but will be patient and sure it s what I want. Thanks for the reply.
[6]
[5] [7]
