[4]
Yamaha Fj1100 Fork Leg Repair
[3]
[10] Like what you see?
Micke S
Oct 9, 2014
465
A friend dropped his bike when it was on a front stand without wheel. So the lower part of the fork leg was broken. I gave it a try and it went better than I thought it would.
The ends where the parts separated was chamfered down into the axle hole. The reason was to be forced to TIG weld well into the axle hole. The sides where then milled and the hole was grinded and honed.
Micke S
Oct 9, 2014
465
Thank you guys ! The fork leg is back on the bike. The axle went thru with a slight resistance and is well secured when the clamping bolt is tightened.
[6]
[5] [7]
