[4]
Yuasa dividing plates
[3]
[10] Like what you see?
chips&more
Mar 19, 2014
2,518
I hear you Mike! But about 5 years ago I retrofitted all my dividing head/table stuff with steppers. I now only have to punch in a division number and go. And can get ALL the division numbers. And even have constant rotation if needed. That 250 bucks for just the plates can go a long way to modify a crank rotary table to digital stepper with readout!...Dave
ronboult
Jul 19, 2012
201
Hi chips&more
Any chance you might give a little more info on the equipment you use to manually control the stepper on your R/T
Thanks Ron
Aukai
H-M Supporter - Gold Member
Oct 4, 2016
646
I have an 8" Yuasa type rotary table, but no dividing plates, shipping's a bit stiff.
mikey
Dec 20, 2012
5,121
Email them. This seller will ship flat rate USPS. I've bought several items from them and they're flexible.
D
Deleted member 43583
Guest - Please Register!
I wonder if they would fit an 8" Vertex?
I assume they would.
petcnc
Dec 29, 2012
297
Hi chips&more
Thanks Ron
An interesting electronic controller could be found here (no relation to Steve Ward)
You can either build it from scratch according to the instructions given (I have already build it and tested it) or, you can buy it constructed and just add the enclosure stepper motors and some sort of rotary head.
p&p should be cheap for you as the guy resides in the UK
mikey
Dec 20, 2012
5,121
The Vertex plate set is cheaper. I have seen threads where guys have used Vertex plates on Yuasa RTs but I cannot say from personal experience. I have the plate set from Yuasa for my 6" and can say that the quality is very good.
coffmajt
H-M Platinum Supporter ($50)
Sep 25, 2013
201
I needed some metric transposing gears for my South Bend 9A so I made the dividing plates that I needed with my lathe and my mill (which has a very useful DRO bolt circle function built in) Gears worked perfectly so then the metric threads i needed to cut were easily done -- Jack
[6]
[5] [7]
