- Dec 3, 2020
- 180
I have a buffer with a polishing wheel (cotton buff). Just a generic 3/4 HP 3-phase TEFC motor bolted to the bench, driven by a cheap KB (USA) VFD, model KBMA-24d, running on nominal 120V input power. That drive is spec'd for a 1 HP (max) motor, and worked fine with that motor for maybe a few hours of cumulative use, just a few minutes at a time usually. Until one day it didn't. I never heard a zap or saw magic smoke escaping the box, it just seemed bricked, not even the power-on light came on. Maybe squeezing three-quarters of a pony out of that drive while on 120 V was unwise? Maybe because of large start-up load with that big 10" buff on there? Or when I really leaned into it while buffing — but again, it didn't stop working while I was using it. It worked one day, then didn't work the next time I switched it on.
Actually I didn't know if it was the VFD or the motor that was bad, but 3-phase motors seem super reliable in my experience, so I was betting the problem was in the drive.
On a hunch, I changed the input power to 240V (just a jumper inside the case), changed the plug, and plugged it in to a 240 V socket. Works like new (for now anyway!)
I will probably not delve any deeper, I don't need to know what went wrong, just a little curious. My working hypothesis is I fried some component (transformer?) that's only used when input is 120 V. For the same horsepower, I was using twice the current at 120 V, right? Now with half the amps on 240 V, maybe I'll be fine now (touch wood), hope I didn't just jinx it.
This is my primitive level of understanding of electrical power. It's all voodoo magic as far as I'm concerned.
I have another identical KBMA-24d driving a 1 HP motor on my drill press, also running on 120 V input. That one gets a lot more use than the buffer and hasn't failed yet, so maybe the drive on the buffer was just bad somehow. Or my drill press motor never gets to deliver a whole horsepower, because the belt always slips before that happens? This cheap POS drill press is the bane of my existence, the way the belt slipping limits the power it can deliver, but I live with it because I'm poor, and I can always drill on the milling machine. I have made some decent holes with it though, like pushing a 2" holesaw through 3/4" thick 6061. It's not totally useless.
