- Dec 18, 2019
- 6,621
I'm thinking of using a2+ to assemble a male taper into a female socket. The two cases of interest would if the tapers match, or if they don't. How would one constrain the system? I want to insert the taper until there is interference or a perfect fit.
Axis coincident, and ?
If you need a model, it will take a little bit. I have the bodies all in the same file, and need to split them into separate files.
