- Feb 2, 2013
- 3,671
Thanks Cadillac,Gosh looks like you needed a third had for all the controls. That setup is for a pedal start operation. You’d press on the gas pedal which has a micro switch which would control a start solenoid to give the starter power. Once started the starter converts to a alternator internally.
Fuel is usually delivered by a diaphragm style operated of crankcase vacuum. Their should be a vacuum line coming off the top of engine behindish the carb.
Those engines vibrate till they get up to speed then smooth out. Never ran one on a bench always in vehicle. She runs like a top great job.
Your very welcome for the parts good to see them get put to use!
i could have used another set of paws!!!!
i was wondering about the starting circuit, it's just like some golf carts i've seen
the diaphragm fuel pump is attached to the motor and started functioning ,best i could tell
i wouldn't suggest anyone run it like i did !!!
