- Oct 7, 2012
- 20
The table right end brackets seem to get broken on the majority of No. 12s. I bet it's because the table is power fed to the left, running the bracket into the saddle. I note that both the permanaent and moveable stops on the right side of your table are missing. I don't know why so many of them get taken off. You'll want to replace them before you use the power feed.
Have a look at the teeth on the ring gear and see if there is obvious wear on the teeth.
Cal
The teeth look good, the stops I pulled off during the remove and quick cleaning. Thanks for the tips. I've been digging up information on these vn12s and your name always pops up with great info. thanks for posting all that too. lol...
