- Oct 15, 2013
- 298
Am in the process of slowly getting my Atlas TH54 in operation. When I bought it, it came with tubs of tooling & parts. Most of it I know about, some of it is unknown (to me..). Can anybody identify these items? What are they & what's thier purpose? I'd love to know!
Thanks!! Wes
#1- two identical threaded assemblies. Are 3.5" tall collapsed; threaded end extends ~2". Base is 1.68" dia & ID is tapered inwards. A leveler of sorts??
#2- One single piece. Has a kniurled shaft 1.0 dia x 2" long, drilled thru. At the end is a tapered "bell" (2" dia at opening) ID is taper bored, leaving about .12" wall.
#3- This assy has a bearing in the center, allowing the ends to spin freely. Seems to be a live center of some sort. Doesnt seem to match the headstock/chuck or tailstock in any way I can see (but then that's me..ha).
#4- This assy is homemade, some edges flamecut, some surfaces nicely milled. There is a pivot at one end allows the small plate to pivot up.
Thanks!! Wes
