- Nov 17, 2015
- 47
I am in the process of cleaning/spindle my mill is 12-7410 and I have fe questions:
1. Is the manual available online the right one for my VN12?
2. What is the modern cross number for the seal the goes on the front bearing?-Solved See Below
3 after cleaning it with kerosene I notice the ring gear can move a bit on the spindle before it "catches" then the spindle will turn is this normal?
UPDATE:
Upon disassembly I found the part number for the seal is #16072. This was originally a Chicago Rawhide part. Do not buy a Chicago Rawhide replacement unless you want a seal that has been deteriorating for at least ten years on a shelf. SKF decided to eliminate the CR brand form their lineup in 2005 so an CR boxed seals are at least 9 years or more old. The part number is the same, however.
PP
UPDATE:
PP
