- Jan 4, 2021
- 1,965
Added Machines & Tools List (below Video Link)
My Shop Machines & Tools (and add-ons)
Bench Machines
MicroLux
Little Machine Shop
BACHIN MINIQ
Craftsman
WEN
DeWalt
Proxxon
FKS/E 3” Tilt Arbor Table Saw
Central Machinery
Ryobi
4” x 36” Belt Sander
Delta
Foredom
Drill Doctor
WorkSharp 2000
Hand Power Tools - 120VAC
Bosch
Craftsman
Dremel 280 Moto-Tool w/Stand
Foredom-Style Flex-Shaft Tool
Mini Flex-Shaft Tool
Ryobi
MicroLux
Skill
Mini Hand Power Tools - 120VAC w/Transformer
Black & Decker
MicroLux
Battery-Powered Tools
Black & Decker
Bosch
Craftsman C3 19.2V
Milwaukee
Proxxon
Other Bench & Fabricating Tools
Central Machinery
MicroLux
Little Machine Shop
Eastwood
I think that's everything, but I'll update if I find something else (or buy something?).
Bench Machines
MicroLux
7” x 16” Mini-Lathe
Micromark Tachometer
LMS Extended Cross-Slide Travel Kit
LMS Rotary Encoder DRO’s on Compound & Tail Stock
Modified LMS Carriage Lock
Mansfield Customs (eBay) Carriage Stop
Swarf Shield
LMS Telescoping Lead Screw Covers
Cross-Feed & Compound Locks
2-Axis iGaging/TouchDRO
Micro-Mill
3-Speed Mini Drill Press w/X-Y Table
Scroll/Coping Saw
2” x 5-1/2” Drum Thickness Sander
2-1/4” Mini Table Saw
3-1/4” Mini Chop Saw
Little Machine Shop
3990 Mini-Mill
LMS 2” Riser Block
LMS Tachometer
Smaller X- & Y-Axis Locking Levers
Priest Tools Deluxe Spindle Brake
Phenom Engineering Y-Axis Thrust Bearing Kit
LMS X-Axis Power Feed
3-Axis iGaging/TouchDRO
Upgraded Y-Axis Bellows (McMaster 1320K141)
Z-Axis Fine Feed Knob w/Handle
Flexible Task Light (Amazon ASIN B09VDLB4JH)
Z-Axis Coarse Feed Hand Wheel
BACHIN MINIQ
13mm Bench Drill
Craftsman
10” 3-Wheel Band Saw
16” Scroll Saw
2” x 42” Belt Sander/6” Disk Sander
Utility Sharpener
WEN
Oscillating Spindle Sander
DeWalt
DWM120 Variable Speed, 4-3/4” x 5” Deep Cut Band Saw mounted on SWAG Off Road Portaband Pro Table
Proxxon
Central Machinery
1” x 30” Belt Sander
3” Grinder/Buffer
Ryobi
Delta
8” x 1” Bench Grinder w/ 8” x 1” Deburring & 80 Grit Al2O3 Wheels
Foredom
2” Jeweler’s Grinder/Buffer
Drill Doctor
750X with 100, 180 & 220 Grit Wheels
WorkSharp 2000
Bosch
Oscillating Multi-Tool
Craftsman
4-1/2" Angle Grinder
Twin-Blade Cutter
“Mouse” Detail Sander
Ryobi
Power Chisel/Gouge
MicroLux
Power Nibbler
Skill
1/2" Hammer Drill
Variable Speed Orbital Jig Saw
Black & Decker
Orbital Sander
Jig Saw
Rotary Tool
MicroLux
Sword Saw
Jig Saw w/Table
“Gourd” Saw (Jig/Coping Saw for curved/irregular surfaces)
Belt Sander w/Table
Orbital Sander
Contour Sander
Plunge Router
Sander/Filer
Right Angle Sander/Drill
1/4” Drill
Black & Decker
HandiSaw
Bosch
10.8V 1/4" Hex Driver
12V 3/8" Drill
12V 3/8" Right Angle Drill
Craftsman C3 19.2V
1/2" Impact Wrench
1/2" Hammer Drill
3/8" Drill/Driver
Max-Axess Ratchet (GearWrench Compatible)
5-1/2" Circular Saw
Reciprocating Saw
Corner Detail Sander
2” Planer
Hand Vacuum
Small Shop Vacuum
Hi-Intensity LED Flashlight
CLED Worklight
Swivel Head Xenon Worklight
Halogen Spotlight
Milwaukee
M12 Right Angle Die Grinder
Proxxon
Rotary Tool w/Bench & Lathe Mounts
Central Machinery
1T Arbor Press w/Hand Wheel & Ratchet Mods
MicroLux
1/2T Arbor Press w/Hand Wheel & Ratchet Mods
Mini Staking Press
Mini Roller/Bender
Little Machine Shop
8” Shear/Brake
Eastwood
18” Bender/Brake
Handheld Metal Hole Punch Set
