I thought I'd share my 4th axis project with the group here. I was gifted a Tsudakoma RZ-150R Indexer. I have a need for 4th axis capability, so this seemed like a good way to start.
After removing the cover over the motor, I found this unit had a 400w induction motor. I learned this isn't the easiest or cheapest way to power an axis, so I'm in the process of replacing that motor with a 400w servomotor from Stepperonline. No data was immediately available for this motor or for the encoder attached to it. I'm also looking forward to shedding a good bit of weight - that induction motor is heavy!
Something I don't know is the technical differences between indexers and rotary axes. Is there a difference in hardware, or just the controls and drive motors? To the uninitiated, they look to be very similar.
