- Jan 27, 2019
- 3
Hello All.
I picked up a enco 2hp mill drill and the electric motor decided to die within a couple of minutes of ownership.
The dilemma, I am not getting any support from MSC for a replacement and can not locate an aftermarket motor.
The motor is a 2hp single phase 90l frame with a 19mm shaft with the keyway machined to the end. It also has a b5 flange.
I do have access to a static convertor and or a rotary convertor if needed but would like to use single phase if able.
Des anyone have a grizzly 2hp mill drill and know the shaft frame size?
I received a quote of 1500 from 3 places to rewind, has to be a cheaper better way?
