- Dec 2, 2012
- 1,741
I have never use one of these machines, but I think I get it.....when changing tooling you sometimes need to move the head due to the length of the tooling before it goes back up into the spindle....like a drill press. On my drill press I expect to be able to change tools (say go to a larger diameter bit) with the work clamped to the table and just simply drill, change and drill again all on the same centre. However, sometimes the tooling is too long......then I need to un-clamp the table, and therefore lose rotational reference. Major bummer!
The difference is unclamping the head with the mill and the table with my drill press.
Something you try to plan for and workaround, unless you can't then you re-centre and move along....what a PITA!
Thanks guys!
Thanks for the education.
-brino
I suspect this info to be useful to the OP in evaluating this machine....hopefully this is not seen as a thread hijack.
Brino has described the biggest issue with a round coloum mill , hence why I don't use a drill chuck on it and all tooling goes into a collet chuck, this instantly helps with not having to adjust the height so often.
I tend to make a quick list of the order of operations for anything that is beyond a very simple part. This helps with reducing the "ow i've got to change the height and re center on the part" issues
The one charles linked to on craigs list has a broken down feed knob, to me thats indicitive of it having fallen over on it's face.
On the issue of tramming , i did try and play that game once, found it to be quite a futile excercise as in my case any very fine adjustment was lost as soon as you move up or down the coloum and re clamp.
I would say they have a tolerance level and generly it's best to work around and with it than try to make it go away entirely.
Basicaly they are not a bridgeport, they wont hold the tolerance of a knee mill, they are however a lot cheeper and lighter. This should all be taken into account when looking at them and inform your choices.
If you get. Chance for a bridgeport for 300 dollars defo go for that though althouh all the regular caviats of does it have a crack in the casting or is their large chunks milling from the slide ways etc. etc.
Stuart
