Is there anyone who can make or have the technical drawings for the gears of a southbend 9" lathe?
I know the amount of teeth, the module and the centerhole.
It's for 3D printing so if possible in digital.
Not sure if this applies to what you are asking - but just a thought.
You could take the specs of the gears needed and look up the available gears on the Boston Gear website. They have downloadable 3d prints for the gears - in many formats. Load the model into your software -like Solidworks or Fusion 360- and modify the bore if needed. . Run it through your printing software. That is assuming the models are accurate. May be worth a try.
