- Oct 24, 2013
- 149
Hi all:
I got a LMS 3960 late last summer & am pleased with it after I installed a power feed unit on the X axis, air counterbalance, tach, DRO on the X & Y axes [all available from LMS] & trammed it. I had to tram mine a second time because I removed the column to make it easier to orient the base & saddle to where it was easiest to drill & tap them & install the DRO scales. I trammed the column using just one indicator & had problems getting it right until I figured out what was happening. Here's how I did it: http://www.hobby-machinist.com/showthread.php/19364-Tramming-made-easy!!!!?p=162899#post162899 A couple more things I found that make this a better machine are [1] the tach mounts to a plate by the spindle motor by means of glued-on magnets. These magnets are no match for the forces of gravity & normal vibration so the tach was always falling off while the mill was running until I replaced the magnets with mounting screws. [2] Another worthwhile improvement if you use a vise with the mill is to add a couple keys in the slots under the vise so it's always square with the table. And remember it only weighs about 124 lbs. so it'll vibrate [a lot] if you push it too hard but it's easy to run & work on & it makes good parts for me & I'm no expert.
