- Aug 26, 2013
- 35
I'm having difficulty separating the column from the base. I've removed the large cap head bolts from inside the base. I can see the join line around some of the column. I have tried lifting with the aid of a small engine crane a couple of inches and tapping with a soft hammer. Nothing is moving. It appears, having removed all the paint from the join area that part of the join line has been welded over and ground back smooth. There doesn't appear to be any repair. I was considering lightly grinding to see if it exposes the join. Does anyone have any other recommendations?
Sent from my iPhone using Tapatalk - now Free
