T-Slot Base for new lathe tool post.
aluminum
Nov 8, 2023
57
I'm just starting out with a new lathe and I bought a new tool post. The new Aloris style post came with a base that needs to machined as a T-Slot. The base on the original turret post has a different thread so i cannot use the original one. I don't have a milling machine yet. I am hoping someone near Denver, CO would be willing to machine this with the T-Slot for me at a price that won't break my bank.
If I were doing this myself, I would face the bottom, then bring the top down to final thickness, and then cut the slots on the side. It is already drilled and tapped. I don't have a whole lot of machining experience but I am pretty sure it's this simple. Someone more experienced may have a different opinion. I'm open to better or different ways, but just trying to be descriptive. I'll add some additional photos soon.
Thank you for your input.
You can put the stud in the T-nut, chuck up by the stud, face the bottom. Remove part from chuck, reverse the stud location, chuck up & face the top. Then mount the T-nut on the compound and using an end mill in the chuck to cut the steps. Necessity is the mother of invention.
Thank you. I may give this a shot, especially the facing, but it seems like it would be difficult to get the right height positioned in the compound and get it square. I don't have a lot of shim stock or even a parallel set yet, nor any experience trying to mill in a lathe. I am also having trouble getting my tool height correct in the original/stock tool post that I have. Once I get my new tool post mounted, I'll have a lot more tooling and options available for doing things like this.
I'll hold out a little longer for some help from someone with a mill. Thank you again. Good suggestion.
Welcome to the forum!!
I think my first project on my 1941 South Bend 13 was machining the same part.
Of course back then it was a bit more complicated for me.
Fortunately I had a clapped out Bridgeport for the job.
Do you have a feeler gage set that comes apart in separate leafs? And a dial test indicator with magnetic base?
I believe there's no requirement for this part to be rectangular. Couldn't you do as above and cut a relief on the top side circular in the lathe?
I have also done these with an angle grinder and a file.
John
Did you ever get this resolved? If not, I may be able to help you out.
