Resolved Ad blocker notice
AGCB97
H-M Lifetime Diamond Member
Apr 22, 2016
968
I'm a diamond member and I'm now getting lots of ads AND notice to stop using my Ad Blocker. What gives?
Aaron
Aaron, are you still getting ads. I checked your permissions. All is good from where I sit. When I view your permissions and views, I'm not seeing ads. Is it still a problem? If so, are you actually running and ad blocker?
If so, what browser are you running?
Upvote 0
See this thread. You may be clicking on an old link in the forum somewhere that doesn't use the most recent htpaccess syntax. The thread explains this. This will cause the ad blocker problem to become intermittent, thinking that are you not logged in and detecting an ad blocker running in the background.
After reviewing the thread I pointed out to you, does this resemble your problem? Also, if so, can you point me to the thread or give a screen shot here so I can better understand which url link address could be the culprit here?
I'm guessing this is the issue but will need the screenshots or addresses of the page you are on when the ad blocker warning pops up.
Upvote 0
No. The ads have now disappeared. Thanks.
Aaron
Upvote 0
