- Apr 9, 2023
- 225
I used to work in the bearing industry, I make this statement on just about every bearing thread, counterfeiting is rampant with bearings, even though you will pay through the nose, it is best to buy from an authorized distributor to make sure you are getting an authentic bearing. You might be safer with inch series bearings since those are not usually made overseas, but it is prudent to be careful about where you buy them.
Thank you for that warning. I wouldn't have thought that bearings were a heavily-faked thing.
I used a couple screw drivers to pry it off, mine was not on too hard, but wouldn’t come off without some persuading. That area is aluminum, so you want to be careful when prying it off and just do a little bit at a time.
I was thinking about some plastic wedges, or something similar.
