- May 17, 2015
- 165
Quick update, I have ordered a set of needle rollers these have an inner and outer race, will need to machine both the shaft and the housing for them to fit.
Hopefully a cheaper option to repairing the shaft and housing to still being only able to fit a bronze bush back in. Still not sure if it was built with brass bushes or this is a previous repair.
What are peoples thoughts on cleaning out the headstock ? I was going to drain and flush with shellite and refill, just worried about contamination in those Gamet bearings. I could see a small amount of brass material in the little feed cup arrangement that feeds the front spindle bearing, Not enough to cause damage Id think, but still don't want to go through this and then have those fail.
