- Feb 2, 2013
- 3,628
Yes
That will work. I think that the way the terminals are set up it would be better to connect 6 to 2-3 and 5 to 4 or 1. The OEM jumpers are set up for that arrangement.
I must agreeThat will work. I think that the way the terminals are set up it would be better to connect 6 to 2-3 and 5 to 4 or 1. The OEM jumpers are set up for that arrangement.
Does your mill have a switch to reverse motor direction? I may be wrong here but if it only has an on/off switch you are wired correctly for "right" rotation of the motor.
`Have you made chips yet or are you going to milk it out for another couple of threads?
When I got my mill, and didn't have a plug yet, I stripped the wires off and wired it directly to the line, you know, like a real machinist would do as the electrician shakes his head.Anyone have a 20 220v plug?
