- Nov 21, 2012
- Location
- Kongsberg, Norway
I found that the least painful arrangement for me was to have all the machines on one side, storage and pegboard on the opposite side. Had a nice little bruise on my back from stepping back from the drill press right into the handle of the Atlas horiz mill's Z handwheel. Right angles may work as well in the corners if possible. I used graph paper and cutouts, too.
I have been considering going this route but it makes the container very one sided with regards to weight. This may cause some issues with stability later. I also have the added challenge that I have a wood bandsaw and metal bandsaw that are quite high and will interfere with the cupboards I will be installing. The plan is to have cupboards with plastic tubs that hold my small items so that the cupboards can be closed and locked to avoid spilling items under transport. This quite a challenging puzzle however I need to get the container insulated first, rust proofed (I am thinking of zinc cathodes attached in the walls and ceiling) and electricity connected. The placement of the powerpoints depends on machine placement of course but I need to get an RPC installed into an electrical cabinet with my transformer from 230 - 400 volt 3 phase and my step down / up from 230 - 110 single phase. Oh, and I need to get some decent lighting organized ASAP.
On a positive note, the container arrived today however I am in Houston on business so I can't do anything for 10 days
Paul.
