20 Tooth Stud Gear For Sb 9a
buddy3223
Apr 25, 2014
47
FOUND need 20 tooth stud gear for SB 9A. :D
buddy, I've got a bunch of SB gears from '70s school lathes, but none are marked. Can you give me the arbor size, diameter, overall thickness and gear thickness? Most of these gears were from the Hvy10 but there were a bunch of 9N gearbox gears. Give me some numbers and I'll check.--David
The gear is as follows:
3/8 (.375) thick
9/16 (.562) hole for shaft
1.374 approximate diameter
The gear is flat with no shoulder and one (1) keyway
The gear teeth are straight cut
Thanks for your reply
