F
Firestopper
Forum Guest
Register Today
I was taught many moons ago (HS) and reinforced in the Navy to never grind nonferrous material on a bench/pedestal grinder. I have seen first hand a heavily "packed" wheel from someone in the shop grinding aluminum.Firestopper, why would you not grind aluminum?
I Surface grind aluminum regularly, not for heavy removal but for flatness. I use mist coolant and the same wheel, works fine, try it sometime. Just block your alum parts with some steel
I know nothing about surface grinding machines or wheels for nonferrous use (don't have one). Just making sure folks understand the dangers of grinding nonferrous material on commonly found bench grinders.
We got Marks (mksj) new mill delivered and set up. I was surprised to only find one drop deck trailer available for rent in Tucson and they are proud of it too. $150 out the door for a days use. They also hit the customer for $7 on anything that has tires (environmental fee). The deck condition was less than desirable, but we made it work.
![IMG_0184.JPG IMG_0184.JPG](https://www.hobby-machinist.com/data/attachments/94/94070-1d57c8be29e317372e5a2505238032cd.jpg)
We also took along a 4'x4'x 1/4" steel plate to reduce the angle of departure for unloading as we could not take the forklift for unloading. We used a come- along for more control during the unloading. Marks driveway is quite steep, narrow,curved and short so backing in was tricky.
Notice the 1" spacers on the casters, this was a big help in preventing a high center condition even with the steel plate to reduce the angle.
![IMG_0187.JPG IMG_0187.JPG](https://www.hobby-machinist.com/data/attachments/94/94071-acddfd9421dd09b9558d43bead345c15.jpg)
![IMG_0188.JPG IMG_0188.JPG](https://www.hobby-machinist.com/data/attachments/94/94072-f1cb17065a7d22978292edaf35cceb03.jpg)
Edge protectors where used on all corners and painted surfaces as well as 2x4 cribbing.
The mill was located, removed the caster spacers and leveled.
![IMG_0189.JPG IMG_0189.JPG](https://www.hobby-machinist.com/data/attachments/94/94073-195760735bee6a4c01dcc6874c0c0581.jpg)
![IMG_0190.JPG IMG_0190.JPG](https://www.hobby-machinist.com/data/attachments/94/94074-08cd2de0ce664fbe34a9d78c4e924d18.jpg)
The mill now sits as close to the ground as possible (1") at low end leveled.
![IMG_0191.JPG IMG_0191.JPG](https://www.hobby-machinist.com/data/attachments/94/94075-2080339deda5b6ed96791cce4986b7ba.jpg)
Another fun project with excellent results.
Thanks for looking,
Paco
