- Nov 23, 2014
- 2,612
POTD was doing a tryout for a Christmas present for my mom. We lost my dad this past April; natural downward spiral after suffering a stroke 5 1/2 years before. My dad was EXTREMELY proud of serving our country in the United States Marine Corp. I'm making an aluminum memorial plaque for my mom to set in their backyard where they used to sit and feed the squirrels and birds.
The plaque will have the Marine Corp emblem and "Dale R. Hansen 7/5/1936 - 4/18/2019" engraved on it. Found a DXF file of the Marine Corp emblem on the web, downloaded it to my Tormach 1100 and used PathPilot's DXF/conversational routines to generate the G-codes for a 4" tall emblem.
I hope Tormach reads my suggestion note for improvements to PathPilot as the conversion routine does a coolant and spindle OFF command EVERY time it lifts the tool off the work before it moves to the next shape. I cannot think of any reason to do this as it adds quite a bit of time to the routine as after every move the spindle and coolant are turned back on before dropping the spindle for the next cut. Fortunately, NOTEPAD has a global Find/Replace function; went through the routine and changed the 300+ (G-code routine was over 34,000 steps) coolant/spindle OFF commands by adding parenthesis to the lines which make them comments instead of executable commands. The routine does 3 passes, removing the coolant/spindle OFF commands took the run time from over 45 minutes to about 27 minutes.
The routine uses a spring-loaded diamond braille for the engraving. Still learning engraving, started with a finish depth of 0.050" with depth of cuts of 0.020". I did a prototype run on the piece of 1/4" Plexiglas shown below. Will do some engraving on a piece of aluminum and maybe change the DOC's. Again, I have no experience with engraving aluminum with the spring-loaded diamond braille, but displacing the braille by 0.050" doesn't take a tremendous amount of force, so hopefully OK, but the proof will be in the pudding.
Thanks for looking,
Bruce
G-code routine for the Marine Corp emblem running in PathPilot.
Making the first pass in 1/4" Plexiglas
Finished Eagle, Globe, Anchor emblem
Thanks for looking,
Bruce
