2HL Table Trip Dogs
MyLilMule
Jan 4, 2021
928
The 2HL I just acquired were missing both the left and right hand table trip dogs. I figure I will just make replacements when the time comes.
I am looking for dimensions that I can create a drawing from in Fusion 360.
If you have a similarly sized mill (not sure if the 2H or larger would use the same parts as a 1H or 2HL), could you take a few minutes to sketch up some dimensions? I only have a rough idea of what they look like.
Is this what you are looking for? Or are you talking about the angled stops at the ends of the table?
Cheers
Martin
What you have pictured is what I am missing. Thanks for the dimensions!
Based on your drawing and some other things I was able to find on the internets, I came up with this drawing. The dimensions you have are a little different.
I also wasn't able to understand what you were indicating in the TOP view. You have one section and 1.129 and another a .908 (almost 1") - I assume that I should have read that as something else.
But how closely do these match up?
Yeah, I don't even know where I got the .908 from??? Your measurements look good. I even sketched the T on the wrong side! I can spend more time this evening to measure it again. I had just worked 12 hours and wasn't really on the ball! The .437 measurement is critical, as it fits very close in the T slot.
Cheers
Martin
