- Feb 7, 2013
- 2,486
OK folks, so I decided to make a hand wheel for my 9J Gorton as I figured there was little hope in
locating one. I started with the center part making it out of mild steel. After I got the center part done with
the square hole, I started to machine the wheel part. That is where the progress part begins. It turns
out that the big cylinder part I used for the wheel must be cast iron! Well, progress, although usually thought of in a forward sense can also progress in reverse. I tried arc welding the center to the outer part with not much success.
OK then, I got out the torch and brazed the wheel onto the hub. Had I known, I would have made the
whole thing out of cast iron but I had several hours invested in making the square hole. Actually I'm not sure
what material the wheel really is. It is magnetic and has some cast iron properties but all the chips that
came off it are brown! Anyway, the project is progressing and WILL be a hand wheel eventually.
I did a test fit of the new wheel on the mill and it fits and has great concentricity so it WILL be a
hand wheel shortly. I need to finish the handle part and polish and paint and it will work out
OK. Ya just gotta love progress sometimes!
Any ideas on what kind of material I am working with? I can only guess...
View media item 96548
View media item 96549
