Got my new lathe in and ordered it with an Aloris BXA tool post and 2 Aloris holders. This week I've been working on cleaning and getting it all set up and decided to use the 2 Aloris holders for my primary turning tool and threading tool. I set the turning tool to height by using the live center and making both points meet, I lock it with the lock ring and tightened the nut and moved it back to the turning side of the tool post and faced some aluminum and noticed there was a small point in the center so I readjusted and locked everything back down and it was perfect. So today i go back and was facing and again there was a small bump in the center indicating the tool wasn't proper height. So I adjusted and noticed that when I tighten the lock nut down it is at an angle and when releasing tool it levels out and changes height. The other one isn't like this and I heard all these great things about Aloris but have never had any issue like this this with the import holders.
Any ideas? Attached is a picture with the ring and nut loose.
