- Feb 1, 2015
- 9,678
The weight isn't that great. Once the saddle is free, you can slide the apron either toward the headstock or the tailstock . You can put a block of wood under the apron for support if you're concerned.I thought that might be true, but wasn't sure. Will need to prop up the apron first, because that's a lot of weight on the lead screw.
