Another Harbor Freight 20 Ton Upfit
Janderso
Jeff Anderson
H-M Platinum Supporter
Mar 26, 2018
8,434
The first thing I noticed about this press is the lack of vertical stability. I welded on some triangular plates once squared.
I am also replacing the press mounting plate. The one that it comes with is loose and tilts plus they used very thin metal.
I am going to weld on two plates with bored holes for the press shaft/pin. I plan on making different size adapters that can be installed/removed by a simple set screw.
Stay tuned.
I didn't get too carried away but it sure is much better.
With the braces welded on the floor legs and the new home made jack support, it is awesome.
I have found the most useful thing is to gather up a bunch of parallels, adapters, cones, bushings etc.
I also drilled holes in the plates so they wouldn't fall on my foot. I drilled and pinned the adjustment pins as well.
Just trying to make it more usable. My God, these things are scary right out of the box.
Someday I'll buy one and come back to this post and copy your modifications. They look like they strengthen the press considerably.
I also purchased one of the 12 ton presses and am pretty pleased with it for what it cost. I did some upgrades to mine also to help with loose fitting pieces and I did make different press adaptors that are interchangeable as well mine use set screw to hold in place. When I made my adaptors I also cut the welded pin a bit shorter because it was way to long. I really like the idea of those pins in the plates if you don't mind I am going to copy that. Another thing I just did a week ago was raise the press up off the floor about 12 inches I was always on my knees to work with the press just got old. The other thing I did was make an inexpensive lift for the press plate it was all done with stuff I had on hand. Thanks for the plate idea. !!!:)
An idea I stole from someone is to use rare earth magnets in adapters to hold them in place. Works great! I ordered some 1/2" dia x 1/8" thk magnets (if I remember correctly) from eBay and so far have three different adapters that "snap" into place and stay there tight.
Ted
Ted
Ted,
Speaking of magnets, I had 3 small squares, 3/8" square. They came with my Bridgeport Mill vice. Those little suckers are amazing.
Super strong magnets. I use them to hold a piece of paper to keep chips/swarf off my DRO on the mill table.
My next project is to make shields for the DRO. I don't have a way of bending sheet metal.
(It's my thread, I can go a different direction right?)
Google bending brake for a press and I'm sure you'll get some ideas. I've seen them where they use heavy gauge angle iron to make a small break. They will actually bend some fairly heavy stuff too... You can buy them too, but I think I'll make my own some day.
Ted
i Built a nice one for mine. They work very well and versatile. One thing you should consider is a segmented upper die. Just like a finger brake. I actually just got a pallet of upper and lower dies from a auction. Gooseneck, deep upper dies all different lowers. I have a lot of different lengths up to 5’. All you’d need to do is build the receiver parts for dies out of plain bar stock.
