I have no idea why the 64T gear doesn't say 64A. But if it has a 1/2" hub length, it is a 64A regardless of what shows up on the side. First, unless you are determined to convert your 101.07403 to a 101.07401, you do NOT want to even think about converting the gears to the 3/8" hub non-A configuration. The total hub length of the 64T + 20T and the 48T + 20T should be 1.0 ". The length of the 10-73A Sleeve, not including the flange thickness, should be about 1.015".
