- Nov 18, 2016
- 19
The 12" Atlas/Craftsman lathe you have there is definitely the bench-mount, not the underdrive model. The underdrives had only two pulleys on the spindle shaft and both were the same diameter. (See the photo >here< on Tony's lathes.co.uk website.) The speed-change pulleys were mounted below the top of the cabinet. Your spindle has the four speed-change pulleys on it so it would have had the motor mounted behind on the countershaft assembly you noted above as absent. You will, indeed, need that assembly to run the lathe. As my Craftsman 12" is currently apart I can take photos of the countershaft assemby, should you need them.
