It might make a good motor for a woodworking tool like a table saw, jointer or planer. I believe it has a 5/8" straight shaft. Assuming it works $50 is a decent price.
For $50 I'd grab it in hopes the pressure washer pump was good or rebuildable. It probably has a 5/8 keyed shaft, most of those pumps have a 5/8 female input. If the pump is trash, you've got a good motor.
Most important question, " IS THE PUMP FROZEN ON THE MOTOR SHAFT " ? Pressure washer pump like this one are famous for freezing to the motor shaft if not properly prepared when assembled.
