I copied this from my other thread.
Okay. I learned a ton today.
The knob in the carriage handwheel is the clutch for the carriage power feed.
The knob in the middle is the power feed for the cross slide. That clutch was very, very stuck.....
The grinding was from the carriage feed clutch not fully disengaging. I had to pull the clutch knob off and the handwheel and clean it all up and get lots of oil onto everything.
The cross slide clutch needed some tapping with a plastic hammer and working back and forth and it finally released. Then I pulled it and cleaned everything.
Now the carriage moves super smooth with no gear noise. No need to pull the apron now.
I will add that I pulled the compound and cross slide and cleaned and stoned everything. I decided to leave the taper attachment off for now.
The lathe is amazing....I can't wait to make chips.
