- Feb 7, 2011
- 5,039
The speeds & feeds I quoted were with the bar in it's normal position with the neg rake. I didn't go heavier than .040 doc because it's only a 3/8 bar. Your post did make me realize two things. Although the bar didn't cut well with the original insert, I have replaced that one with the same ones that I use for the rest of my insert bars which are for external cuts. This may be a contributor. The second thing you made me realize is that although this bar cuts great at zero rake I tried it in a one inch hole, not the .458 hole that I'll be using it in on my project. It's possible that I won't have sufficient clearance in the smaller hole. I'll have to try it in some scrap. At lest with the adaptor I made I can use any rake angle I want including the factory angle. Thx for the help.
That changes things. What is the number of the insert that you are using. And what is the number of the insert that came with it.
