Bought Clausing 6900 series lathe, has 7/8-14 leveling bolts but no isolator feet
Super! When you started discussing degrees off of level I just wanted to make sure you knew that level to the world didn't have to be the goal. Dead level is probably easier than estimating portions of a bubble off, though.
Since ships were mentioned, I found out a couple of days ago that we may have a functional machine shop on the USS Texas again before too long. How cool would that be? Can you imagine machining on this?
If I could drive that far I would drive down to Corpus just to see that lathe. I would love to see it. Thanks for posting this picture.
Its actually at Gulf Copper Ship Yard near Galveston TX Currently. I hear rumor they are planning to make Galveston the USS Texas's new home, Know anything about that David2011?
Didn't it used to be in Corpus? Or is my feeble mind lost somewhere else.
The Lexington in in Corpus, the Texas was located at the San Jacinta Battle ground across from the Monument technically In Houston.
Wow that's an awesome picture and context! Thanks for the background on that! I will hopefully take some test cuts tomorrow now that I have it dialed in a bit more reasonably.
The ship will be moored at Pier 21 on the Galveston Ship Channel, directly across the channel from where the repairs are being done at Gulf Copper. That's between the cruise ship docks and where the tall ship Elissa is moored. The agreement is pending finalization right now.
This is a picture looking south from Pelican Island toward Galveston Island taken before the ship was put back in the water, still sitting in the dry dock. She has since been moved to the pier in the area marked by the heavy yellow outline. Pier 21 is across the channel and the ship's new home will be in the light yellow outline.
I'll see if this holds up, depending on the rigidity of the rubber material beneath the steel insert/washer. For now, at least, I was able to get most of the twist out of the bed. It's better than sitting the lathe housing directly down on the concrete.
I'm pretty sure I have a dinged up insert and I know it's just a hair off-center, but I am finally happy with the fact that I've removed the twist out of the bed at least enough to get a 0.0001"-0.0002" deviation across about 6.5" of length. Comparing that with my previous 0.0035" across a ~1.75" length, I'd say I've achieved my goal with this machine that still has several other problems to solve. On small diameter parts the surface finish looked quite a bit better, so maybe the very slightly off-center tool height is contributing to the funny looking surface finish of the part because the problem is worsened with the increased diameter of the material (~.560" vs ~1.770").
Any suggestions on any of this would be appreciated. I know that part of the issue with the small diameter part being so far off was very likely due to someone having drilled the stock without a tailstock or center drill. Maybe they had a longer jobber drill or who knows what to drill what looked like a hole for a live center (which is what I used it for). Regardless of all of that, I definitely know that this machine was cutting a huge taper previously, without a live center on shorter parts.
My much smaller lathe, a 10 x 22, would never settle down on rubber feet. Couldn't level it, it wasn't stable, at least with a sensitive level. I replaced my hockey puck pads with steel pads direct on concrete and was able to level it. So if you can't get the precision you need, try eliminating the rubber.
