- Dec 18, 2019
- 6,538
Seems the hand vacuum pump didn't work... Actually, it felt like someone assembled the pump and forgot to install the o-ring. There was zero resistance in pumping, either the up or down stroke. There was no vacuum being generated, nor any positive presssure. And it appeared the pump was sealed and non-serviceable. Or at least not obvious to me how to disassemble it. So immediately initiated a return stating the pump didn't work. A few days later, A***** sent a replacement. I decided to test the new one, if I have to return them, it's better to do it in one trip.
This pump seems to work. Don't know about the bags how well they hold, but at least one of the bags was pump-able. Guess I should check them all and keep the good ones. Pretty bad quality control if they left out the pump seal. I don't understand why the unit is sealed, why not make it serviceable? A freaking o-ring is a simple, inexpensive repair. Even I can do that!
