- Jul 14, 2017
- 2,451
First off this is my first endeavor in high pressure hydraulics, any advice is much appreciated, i've bought couple of parts over the last few months for the hydraulic side of this build, and i'm leaving the heavy metal frame build for last, many because i'm confident i'll should be able to fabricate it in couple of days.
First of the recently acquired part is a pair of hydraulic cylinders, one come with some fittings and couplers wich i may be able to reuse, the cylinders are stabiliser legs from a crane or a concrete pump, it has a stroke of 55 centimeters shaft diameter 56mm and cylinder inside diameter of 80mm, i've disassembled the first cylinder i got to inspect it and clean it. Also the front of the cylinder has a removable front attachment, using a spring pin, which is ideal for attaching different tooling on it, can someone calculate what pressures i need run to get 20-30 tons out of 80mm cylinder.
