- Nov 16, 2012
This does a fine job when I surface grind. There will always be some residual dust in the immediate area of the grinder table and mag chuck. I run this thing enclosed in my shop and I do not find dust in other areas.
Welding fumes are a different matter all together. If you're concerned about welding fumes, I suspect this unit would serve as a good fan to suck air from one place and blow it out a window. As for protection from organic poisioning, for that, you need a well fitting and appropriately outfitted face mask.
Ray
Ray
Thanks Ray,
that looks like the price is right, but will it get the dust from a surface grinder, as well as any fumes from a spot welder. I have most of my grinding machines in one room, with only one window
to open. I have a full face mask with cartridges and a heap vacuum for any carbide I may grind, but my baldor carbide grinder are in a different room with my other delta grinder for HSS.
THANKS,JON
