there are few parts available for any of the lesser brands of old machine tools. If it works well and is cheap, you can learn how to make replacement parts. The spindle runout and bearings are the go/no go. On a mill, the table wears fastest in the middle. If you tighten the ways to compensate, then it will get stiff or stuck towards the ends. If it was in continuous production then it is likely worn out. If it sat in the corner and was used to make an occasional part then it might have very little wear.
