Hello all,
so every one says,"you gotta grind carbide tooling", but I havent seen advice regarding what size of grinder to use, proper wheel grinding speeds, or actual composition/grit of grinding wheels etc. Do you need two different grits? If so, what is best??
I'd like to put together a carbide grinder. Looking for what constitutes a proper set up.
thanks,
Glenn
thanks,
Glenn
