- Sep 3, 2012
- 51
First: Cast Iron Repair
The main belt cover for the VN-12 is cracked. Over the years people didn't fix it, they just pushed paint into the crack. The cover is a little bent so the crack has opened about 1/16th of an inch. I've removed the paint using dental picks and paint remover.
I'm trying to decide how to fix the cover. Here are the options I know, I'm open to other suggestions.
I don't have access to an arc welder. I've heard that it is a chore to arc weld cast iron correctly (meaning I can't afford to have it done).
Second: Needle Scaler
http://www.harborfreight.com/air-needle-scaler-1108.html
I found an Needle Scaler on the "Open Box" shelf at Harbor Freight for $14.00. I bought it and tried it on the base of the machine. It took paint off like a champ.
The paint is old and cracked and comes off reasonable easy with scraper also.
Is there any problem with using a needle scaler on the cast iron? A needle scaler seems like something the Navy would use on ships to clean up rust and old paint.
Evan R.
- Fill crack with JB Weld clamp it so that the crack closes. Pray a lot while the epoxy hardens.<== I'm leaning towards this one
- Plug it with bondo and sand it smooth.
- Braze it <== I have the tools to braze, but no experience brazing cast iron. I will have difficulty pre-heating the whole cover.
- Forget it, paint over it.
- Chunk it in the trash, we don't need no stink'n belt cover.
Evan R.
