The two wheel pressure knurling tool I purchased with my QCTP did not work well for me. So i decided to make a clamp knurler. After much web searching this is what I decided would be within my capabilities. Both in skill level and equipment. I purchased the wheels from Accu Trak.
That looks like a smart design. The flat plates will hold the arms firmly in alignment. This is a downfall of cheaper units(like mine!). Thanks for posting!
R
Thanks for all the kind words. I don't have any drawings but I will measure the parts tomorrow and post a list of sizes. It will close down until both wheels touch and has clearance to the body to knurl 2"od. So far it has worked flawlessly but I've only used it three times.
Here are the dimensions :
Side plates 3.25 (high) x 3 (wide) x .25 (thick)
Spacer plate Trapezoid shaped Base 2 Top .75 height 2.5 thickness .5
Roller arm .5 x .5 x 4.5
Tool holder bar .5 x .5 x 3
Knurl wheels .75 x .25
