- Sep 22, 2010
- 7,223
Clausing 5900 series lathe model identification chart | ||||
Model | Drive | Between Centers | Counter-shaft | Motor |
5902 | Variable speed | 24" | Clutch / Brake | 1HP / three-phase |
5903 | Variable speed | 24" | Clutch / Brake | 1.5HP / single-phase |
5904 | Variable speed | 24" | Clutch / Brake | 2HP / three-phase |
5907 | Variable speed | 24" | Plain | 1HP / three-phase |
5908 | Variable speed | 24" | Plain | 1.5HP / single-phase |
5909 | Variable speed | 24" | Plain | 2HP / three-phase |
5912 | Variable speed | 36" | Clutch / Brake | 1HP / three-phase |
5913 | Variable speed | 36" | Clutch / Brake | 1.5HP / single-phase |
5914 | Variable speed | 36" | Clutch / Brake | 2HP / three-phase |
5917 | Variable speed | 36" | Plain | 1HP / three-phase |
5918 | Variable speed | 36" | Plain | 1.5HP / single-phase |
5919 | Variable speed | 36" | Plain | 2HP / three-phase |
5920 | Variable speed with 2-speed motor | 24" | Clutch / Brake | 1-2HP / three-phase / 220V |
5921 | Variable speed with 2-speed motor | 24" | Clutch / Brake | 1-2HP / three-phase / 440V |
5922 | Variable speed with 2-speed motor | 36" | Clutch / Brake | 1-2HP / three-phase / 220V |
5923 | Variable speed with 2-speed motor | 36" | Clutch / Brake | 1-2HP / three-phase / 440V |
5930 | Step pulley | 24" | Clutch / Brake | 1.5HP / single-phase |
5931 | Step pulley | 24" | Clutch / Brake | 1HP / three-phase |
5932 | Step pulley | 36" | Clutch / Brake | 1.5HP / single-phase |
5933 | Step pulley | 36" | Clutch / Brake | 1HP / three-phase |
5935 | Step pulley | 24" | Plain | 1.5HP / single-phase |
5936 | Step pulley | 24" | Plain | 1HP / three-phase |
5937 | Step pulley | 36" | Plain | 1.5HP / single-phase |
5938 | Step pulley | 36" | Plain | 1HP / three-phase |
5950 | Variable speed with 2-speed motor | 47" * | Clutch / Brake | 1-2HP / three-phase / 220V |
5951 | Variable speed with 2-speed motor | 47" * | Clutch / Brake | 1-2HP / three-phase / 440V |
5955 | Variable speed with 2-speed motor | 59" ** | Clutch / Brake | 1-2HP / three-phase / 220V |
5956 | Variable speed with 2-speed motor | 59" ** | Clutch / Brake | 1-2HP / three-phase / 440V |
* Power Feed Turret Lathe, same bed as used on 24" Lathe | ||||
** Power Feed Turret Lathe, same bed as used on 36" Lathe |
